bmays »
https://forums.nicoclub.com/bmays-u153594.html
Sun Feb 07, 2010 7:29 pm
ok buddy i have the same truck i had the same problem! You need to remove the head light completly using a air hose blow out the water from your light 100% dry then using a adhesive sealer seal the light all the way around because the seal has been broken somewhere so take no chances.Replace light make sure all connections are tight and connetors are clean. the water proubly cause your light to work on and off. If you do all this it will save you a ton of money my light is back to being clear and perfect!
