Water in headlight.
peter_rabbit
Car: 2003 m45 white pearl, '99 mustang gt vert
Has anyone had the problem of water in the headlight? I have had the car since August and this is the first time it's happened. I can't see how the water got in. Do anyone know of a way to get it out without taking the whole assembly out..????
lfj2025
Car: 2003 Infiniti M45 Black on Black & 2000 Mustang GT convert
This is a new one. Haven't heard of this before.
szh
Car: 2018 Tesla Model 3.
There is a TSB on it ... yes, it has been known to happen to a few cars. There is a condensation drain hole and sometimes this can get blocked too.
I don't have the TSB handy, but I will look for it.
Z
danmeljeff
Car: 2006 M35 Sport (Journey + Adv Tech)
While buying my '06 M35 a few weeks ago, the dealership warned me that the headlight surround might get condensation inside. They too said that if it happens, I should take it into the dealership, because if I tried to fix it myself, I could easily ruin the headlights...which they priced at $2500.
Granted, I was sceptical I could actually ruin the headlights, but while it's under warranty...didn't bother to question it.
If you get the condensation cleared up, let us know what had to be done to fix it.
peter_rabbit
Thanks and i appreciate it. I was online all weekend and i couldn't find anything about the headlight having a drainhole. But i did run across the price of the headlight assembly, $900-$1200. So I guess i'll take the headlight out and check it out when it gets a little warmer.
szh
Okay, correction. I mis-remembered the TSB. It is not a drain hole, but the headlight assembly is vented to the atmosphere, so does get moisture inside. The TSB talks about what is normal amounts and what is not, but does not address what to do if the condition is not normal.
Here it is for reference ... you might want to talk to the dealer about it, I suggest (is your car still under warranty or extended warranty?).
Z
peter_rabbit
I do have an extended warranty but not with Infiniti. I'm due to get the oil change soon so i'll talk to them then...thanks.
Boon
Car: 03 M45 Black on Black Crime
I have two what look to be flys in my brake light if it makes you feel any better. They look wierd cause the sun has taken its toll on them so they look albino. Gives me a reason to work on the car though so I'm okan with it. Hopefully I can get them unstuck and cleaned up without having to bake the lense apart.
auditech10
Car: 03 M45
They will tell you to leave the headlights on for a while in a dry place and the heat should evaporate the water. You can just pull the bulbs out(whichever you can get to easiest) and let the car sit over night in a warm/cool dry place like a garage or something, that should get most of it out.Cheers
peter_rabbit
I was thinking about taking the bulbs out and blowing a little air in to get rid of some of the water. I use to do it on the Stang and there was never a problem. I just don't want the lens to turn that funky brown color. I hate that
