Water in Gas!
ihenson711
Car: 2002 Nissan Sentra SE-R Spec V
Well I think I got some water in my fuel a little while back. Does anyone know how long it takes to normally pass water through. I have filled up 3 times with 93 pump gas, and ran several products through such as seafoam, heet drygas, octane boost, etc... and it still seems to be in there. I have talked to a hand full of people and they have all told me that water can take a long time to actually get fully out of the fuel system. Can anyone confirm this.. has anyone else had this problem.. and what kind of symptoms normally arise?
thanks
Modified by ihenson711 at 7:39 PM 2/9/2008
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
how do you get water in the tank?
just take the fuel line off and prime the system till it runs dry
prime it by removing the ignition fuse then hold the key in the start postion
ihenson711
Hey man.. thanks for the reply. I think I got some water in the gas from the pump if you go back a couple of pages under title " any Ideas" this is where I listed the problems that I have been having. Based on my conversations with differant people, they all said it sounded to them like I got some water from the gas station.
02SPECtacularV
Car: 2002 nissan sentra se-r spec v
well the same shiit happened to me...i took it to a friend of my dads which happens to be a machenic for more then 20 years and he took out my spark plugs and coils and just tried turning it on and just held the key for about 4 seconds and the water that was in there same flying out it wasnt a lot of water a few drops out of each spark plug holding place but by the time i knew there was water in my engine it already done the damage.
