jdmshiz »
https://forums.nicoclub.com/jdmshiz-u117853.html
Fri Sep 16, 2011 5:54 pm
hey guys. 240 single cam ka24.
I just recently did a head gasket job and a few days after I find ALOt of white smoke out my exhaust again... It was out of no where like a snap of the fingers.
When popping open the valve cover to check everything out, a lot of oil spilled out as if it was flooded. It almost seems like to much to be a headgasket. I noticed also there was alot of oil going through the pcv ito the intake. I did a compression check and 1 2 4 read 170 and for some reason 3 reads 210. If a head gasket is blown it shouldn't hold compression right?
My next thing I want to check is the timing cover because water lines runs through it. Maybe it didn't seal right and water spilled directly into the engines oil pan? Oil/water mixture level is about halfway up the timing cover so the engine has to be flooded
Just curious if this has happened to anyone before.. I sure don't want to go through another headgasket job or find out I have a cracked block.
jdmshiz on Fri Sep 16, 2011 6:00 pm, edited 1 time in total.
