Long time lurker, first time poster.
My wife's 2014 Rogue happened to have a soaked headliner on the passenger this past weekend after a storm. After searching this forum, I found the solution. The passenger side sunroof drain tube was clogged. I snaked it, blew it with some air then tested, and it was nice and flowy.
Fast forward two days and I hear the sloshing of water on the passenger side when I brake or go over something bumpy. I again turn to the wisdom here and check the AC drain tube. I used some compressed air in the tube, no water comes out. Nothing was in there and it was draining just fine with the AC blasting.
So here I am, still lost. This is my current status - I tore up the passenger side and found water under the styrofoam subfloor. (I pretty much broke the subfloor too, hope that isn't too terrible.) Its pretty soaked on the insulation (blue stuff). Any suggestions?
PS - Anyone know of a Youtube channel that has a DIY library to help deduce these type of problems? Any help would be greatly appreciated
https://imgur.com/a/bwJPbyz
