cmkelly wrote:This used to happen to my Isuzu Impulse many years ago. It was a blocked line, the one that normall drips out under the car when your AC is running. I had to remove the glovebox then the blower motor and find the drain valve to resolve the problem. Also, if you run the recirculate most often this is likely to happen more as there is more condensation in this mode. Make sure you run "open" as well to reduce condensation.
Good Luck!
are you absolutely sure about that? i think that running it in recirculate mode would create less condensation because it recirculates the air inside the car which has already ran through the a/c system and gotten dehumidified. running on outside air where all the humidity is, will create more condensation. this is why houses recirculate the air instead of pulling it from outside as to create a lower humidity evironment, which is especially helpful in high humidity area like FL for example.
when my nissan pathfinder's a/c got plugged all i did was poke a coat hanger up into the drip tube and it loosened up the debris. it was a bunch of leaves and dirt.
