yes, look under the driverside and you will see a phillips head plastic drain plug on the bottom of the radiator.irichjohn wrote:so the water drain plug is part of the radiator?
It is indeed below the exhaust manifold, but mine is a regular hex bolt.ddgsxr504 wrote:The block drain plug is located under the exhaust manifold, it's a square nut.
