evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Feb 12, 2007 6:57 pm
depends on how much water, if it actually took water into the intake and hydrolocked the motor... you need a new motor, you might be able to drain you're and get it back into shape but plan for the worst and hope for the best, drain all fluids, pull thespark plugs an try turning the engine by hand, if there is any water in you'll pump it out, wd40 inthe spark plug holes, fresh spark plugs, clean all the electrical connections with wire dryer, put it all back together, hold your breathe and your walletalso pull the i/c piping to let any potential water in there out
