masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Thu Jun 03, 2004 5:19 am
FirstDraft8907,
First of all, welcome to the boards, and congrats on your decision to go with a 240. As has been stated, finding the best YEAR will be pretty much dictated by whatever plans you have for the car. For the money you're willing to spend, you'll probably be happiest with an S13. Without going into TOO much detail, let me explain a few things about the models.
89-90 - S13 chassis with the ever venerable "pignose" fender. These models have found a niche in the 240sx community for many reasons, one perhaps being that they were the first iteration of the S13. Both coupe and fastback models were available. They came with the SOHC 2.4L KA24E (yeah, I'm being redundant...) that made about 135-140 hp stock. 91-94 - For all intents and purposes, these models retained the original S13 chassis, excluding the front fender, which was modified to look more modern and aggressive. The MAJOR difference between this model and the previous "pignose" is the stock engine. From 91 on, the car came with a DOHC 2.4L KA24DE, which produced about 155 hp stock. A convertable version was introduced in 92, and was the only model offered in 94.
All of this engine talk will be irrelevant if you're planning on swapping in an SR, CA, or RB. Keep in mind that there are MANY more options for power in the 240sx than "going SR".
NOTE: Try not to be swayed by this talk of the 91 engine having hotter cams. Remember that, even if they DID, the engine is 13-14 years old (depending on DOP).
Good luck man, and again, congratulations!
