53: Exhaust Gas Sensor Circuit (right)
33: Exhaust Gas Sensor Circuit (left)
34: Detonation Sensor Circuit
2) my speedometer shoots up to 55 and stays there
3) my oil pressure gauge doesnt seem to work much either
4) temp gauge seems to be acting up. normal driving no problem, on the highway if im buzzing at 3K in 5th gear the temp goes up a lil past 9:00, then i slow down and drive at 3K 4th gear and it goes down, pulled over no smoke at all. also checked the coolant and its good, took the rad cap off and ran the car to get any bubbles out and its still doing it. WHY?
EDIT: also forgot to add tht i replaced the ecu, checking the fuses tomorrow
