wat should i upgrade on my 240 before i start drifting?
nissandrift818
Car: nissan 240sx
i just got my stock 240sx and im planning to start some serious drifting...what would be good things to start upgrading before i go to the track?I appreciate if u anyone can help.thanks.
ZootedS13
Car: 1990 240sx se
invest in some good coilovers.
if your loaded get a 2way lsd
if your broke like the rest of us get your diff welded.
SketchyRollin564
Car: SR hatchback in the werks
If you have an open diff your gonna want a vlsd. Or if your more hardcore about it and its gonna be mostly a drift car, then you might want to weld it instead (cheaper, but they both have their ups and downs, i personally prefer a vlsd)
If your suspension is all stock, its probably all shot. If you cant afford a set of coilovers, try to find a cheap used set of struts and springs.
its also not a bad idea to replace your tie rods, even if its just with new bushings, cause that makes a big difference on these ancient cars. new tie rods will also give you way better steering feel and wont take a s*** on you. A lot of aftermarket ones come with spacers to give you more steering angle, thats also a +
another cheap thing you can do is get subframe collars. They are like $60 for solid ones and will get rid of the annoying CLUNK you get stepping on and letting off the gas too hard. It will reduce all that play and put more power to the wheels
if you have $250, suspension techniques sells a good pair of thicker adjustable swaybars which also comes with new bushings and endlinks. This will help a lot reducing body roll
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Upgrade on the search button because the horses blood is already dried up and swept away.
nissandrift818
Car: nissan 240sx
thanks guys,what about tires?
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
Just leave it the way it is that way when(NOT IF) you crash it wont hurt so bad. :bigthumb: I need a clutch pedal shipped to 31707.
For when you do the part out. :squint:
nissandrift818
Car: nissan 240sx
anything else?
nissandrift818
Car: nissan 240sx
anything else?
EnjoiNismo
Car: 93 240sx
nissandrift818 wrote:thanks guys,what about tires?
If your learning, have good tires up front.
and buy USED tires for your rear.
ZootedS13
Car: 1990 240sx se
SketchyRollin564 wrote:its also not a bad idea to replace your tie rods
NOt so sure about that, iv seen many aftermarket tie rods snap way easier than the stockers.
nissandrift818
Car: nissan 240sx
thanks,wat about differential...its gonna be lsd of course but should i get it welded or maybe get vlsd?which 1 is gonna work better?
s13k1d
Car: 1991 240sx
like stated if you have the money get a 2way or 1.5 what ever you prefer. if not and are on a budget welded. vlsd is ok. after a run or so if its older will act like an open. i have a vlsd and it sometimes acts up. due to higher miles.
EnjoiNismo
Car: 93 240sx
nissandrift818 wrote:thanks,wat about differential...its gonna be lsd of course but should i get it welded or maybe get vlsd?which 1 is gonna work better?
Welded if your more serious about drifting. Welded will lock better then VLSD.
But vlsd is nice for daily driving.
nissandrift818
Car: nissan 240sx
yea pretty much,im planning to make that car a drift car,ill still use it to go here and there but im really serious about drifting.So in that case welded will be better than vlsd?wat about 2way?
EnjoiNismo
Car: 93 240sx
Correct welded would be better.
2way would be best.... if you can afford $800 for a 2way that is.
nissandrift818
Car: nissan 240sx
yea it will probably be a good idea to buy that 1s i get better...thanks for the help
EnjoiNismo
Car: 93 240sx
Yesss sirrrz Np! :bigthumb:
nissandrift818
Car: nissan 240sx
anything else that would be helpful to upgrade before i start drifting?
EnjoiNismo
Car: 93 240sx
Make sure the car runs good.
I've had a few friends drift a stock s13 only with a welded, and they did it DAMN good!
But coilovers would be next i'd say.
nissandrift818
Car: nissan 240sx
do u think it will do good wen its not welded,just normal?
EnjoiNismo
Car: 93 240sx
Drifting with a open diff?
No it will suck. bad. lol
hatedinthemind
Car: S13 Coupe, Subaru Forester
Bro have you ever gone to an event? If not, weld the diff and go to some events. You dont need a crazy awesome car to drift. You as a driver is more important then any mod that you can put on your car.
nissandrift818
Car: nissan 240sx
yea thats wat i thought lol...is supercharger better than turbocharger for drifting?
AZ89two4Tsx
Don't even think about forced induction until you have:
- Coilovers
- Some kind of differential OTHER than open (stock) or vlsd
- Full suspension tune-up/rebuild/upgrade
- A bucket seat
- A better clutch
- Wheels wider than stock/better tires
- A few events under your belt
When you've done that, then focus on more power.
SketchyRollin564
really? thats the first time ive ever heard that
are the teins any good? cause im about to order those in like half an hour
ZootedS13
Car: 1990 240sx se
my friend broke one of his teins after drifting on it 3 times. maybe it was a fluke, maybe not, but i wont be buying teins. he has been using stockers for a year now and drifts every weekend. they still havent broke.
AZ89two4Tsx
Plus you can get a warranty from your local auto parts store. :P
Gabes13
Car: rb20det s13
Suspension first, then lsd. Then save a ton of money for tires and events.
E7-S14
Car: ess 14 foo!
Some Useful Advice:
Start in a STOCK CAR WITH SOME SORT OF LOCKING REAR END.
Figure out if your going to like it before you dump 5k into your 240 and realize you dont like drifting.
too many times have i come across guys who drop 10k into there cars and haven't entered ONE event. then realize they dont like drifting.
btm88
Car: 1993 S13 Convertible
Seriously just weld our diff, make sure the motor is running strong and has nice clean fluid, possibly get better suspension, then go get some experience. Nothing you add to your car now will benefit you more than to just drive and get a feel for how your car handles. Get really good with your set up now then add the upgrades.
