Yea the 89 maxima clutch is compatible with the SR transmission....a lot of companies do make an application for the SR20det now though, and you can get that....its the same measurements as the maxima clutch. a stock maxima clutch wont hold 400hp, but a stage3, or 6 puck would usually be rated for that much HP, but you would have to find that out...My Iron clutch would hold that much power...and a Clutchmasters stage 4, maybe 3 would...but again, you have to check that...JWT tuned ECU i believe cost 500-600 for the initial tune, and 100 for each upgrade, everytime you send it back to get retuned....its good for someone who doesnt want to have the ability, or need to tune the car on the fly..just plug and let go.....but they do give you upgrades over a stock ecu.....they say not to use them with the S-AFC though..im running stock ecu, with SAFC, but we do have a S13 SR running the JWT, and he loves it....Daunttless wrote:A maxima clutch will not fit. And I very much doubt it would hold 400 horsepower.
JWT tunes the ECU for the SR20, but as I hear they aren't exceptional. Also, I can't imagine it costing less than 500 dollars.
So just to clairify: haltech is just like Hondata, and better than the Apexi system because of laptop tuning? Whats important to me is just buying Dyno time, and doing the tuning myself. I would like to be able to have a few chips burned so I wouldn't have to run 20 psi all the time. Also does the haltech plug into the exsisting harness? Hondata does, and I think that is one of the big selling points. With a standalone (Accel) you have to rewire everything. :thumbdDaunttless wrote:A hondata is a power fc with lap top tuning.
A haltech is exactly the same but better. : ) Laptop tuning, and the ability to load maps. All the hondata did was take a haltech/motec/whatever, and mass produce them for hondas.
