wat is a good fit for s13
peakboostrps13
Car: rps13
im trying to run 18s.. 8 1/2 in front and 9 1/2 in back.. will i be able to? by just rolled fenders?
Modified by peakboostrps13 at 7:32 PM 5/8/2008
Kalypso
you and your peakboost turbo setup
I dont know an exact offset, but you should run 9's all around. for rotation sake.at maybe +25, or even better +15.
if not. stretch tires, pull fenders, and negative camber.
you can do anything, what wheels do you want.
adrianfromthecastle
Car: 1992 Nissan 240sx
peakboostrps13 wrote:im trying to run 18s.. 8 1/2 in front and 9 1/2 in back.. will i be able to? by just rolled fenders?
+15 offset should give you a decent fitment with just a roll... considering you'll be running a slight stretch on your tires.
peakboostrps13
Car: rps13
adrians_s13 wrote:+15 offset should give you a decent fitment with just a roll... considering you'll be running a slight stretch on your tires.
thanks man..
appreciate it
