wastegate vs bov
Abstrakt02
Car: 1993 240sx Hatchback (front end silvia conversion)
can someboody educate me on this please..?
can I have a wastegate and a bov or do I choose between the 2?
also which is better?
duty780
Car: 1993 vert.. sr
every turbo needs a wastegate. It will either be internal (part of the turbo) or external (mounted to the turbo manifold). A blowoff valve is not necessary but it is recommended. What it does is release unused psi so when it comes back, it wont make the turbo propellar go backwards. also, BOV sound great. have fun choosing for sounds!
Abstrakt02
thanks
I'm actually looking for a higher pitch sound
but hks ssqv vs greddy type rs
what do you think?
ELEMENT692121
Car: 93 240 SX SE
i would not have a turbo charged car without a bov unless you plan on replacing turbos very often (hks ssqv is very loud ).. the bov relases the excess pressure in your intake track after the throttle plate is closed and keeps the turbo from trying to backspin ..as for a wastegate this is required to regulate boost from the turbo .. most wastegaes are internal but some people run external gates that vent the unused exaust gases right out before they go through the cat ( if u have one ) or the muffler.. external gates usually allow you to build boost sooner and hold it more steadaly .. equals very loud car once youve reached the boost level that the gate opens at ..
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
actually variable vane turbos do not use wastegates, although its an oem application only so far, i think. it's not something to mess with though until it becomes available to the aftermarket
ELEMENT692121
Car: 93 240 SX SE
ACTUALLY SOME COMPANIES LIKE PORCHE HAVE STARTED USING WASTE GATES WITH THE VARIABLE TURBOS BECAUSE THEY WERE EXPERIANCING OVERBOOST PROBLEMS WITH THE EARLY MODELS ..
matt4pl
thats news to me. i'm not trying to prove anything here, just kinda adding in some new tech info. most of my info on this comes from benz though and they have no issues with the variable vane turbos, but i guess they just built it better, but then again i'm biased
ELEMENT692121
Car: 93 240 SX SE
sorry about the caps lock my girl leaves it on and i forget about it .. i didnt want anyone to think i was yellin or bein a d!ck .. yeah the new technoligy is pretty amazing i think it will great in a few years once theyve perfected the variable turbos ..
