WBSR240 »
https://forums.nicoclub.com/wbsr240-u52065.html
Fri Mar 09, 2007 1:00 pm
Im doing a swap on a s13 Chassis with a s13 redtop SR20Det. Ive read all about the Vacuum lines and it is said that you cant connect the Wastegate into the FPR T nipple. I was wondering why you cant do this?
Also, there is a hose coming from rear of the Intake Manifold, where does this go? Is it a coolant line? I have my heater core removed, so i have no line coming into my firewall. How should i setup my heater hoses properly? What i have done already is with the only 2 outlets(that look like heater heater hoses) coming out be the exhaust side, i connected them with a u pipe. Is this correct? Thank you all for your time, Chris
