Def wrote:It is generally easier for the EBC to regulate your boost if you are shooting for pressures somewhat close to your wastegate spring.
With pressures like that, I'd honestly look for a 10-12psi spring at the minimum. Springs aren't expensive, and the right one will give the EBC a much easier time.
