wastegate RPM dependant?
MikeMurphy
Car: Guess
Is there such a thing out there that will control the wastegate via pressure readings (as usual) and then override those readings with user inputted values based on RPM? I was checking out greddy's profrec e-01 in combination with emanage but im not abosulutly sure.
"With both an Auto and Manual setting for both external and actuator style wastegates, the new PRofec can alter its new compact, high capacity solenoid valve via various RPM ranges if need be."
Has anyone used this product and feature specifically?
a pat on the back for anyone who can confirm this and another pat on the back if someone could guess the application im thinking of.
MikeMurphy
Car: Guess
nobody?!
Nismo_Freak
Car: 89 Nissan 240SX
Can't really see why you would want it that way but I'm sure most of the aftermarket ECUs like Motec, Haltech, are capable of doing something like that.
