Wastegate Question
IvanS13
Car: *** & Titties
What are the advantages, if any, is it to have a larger mm external wastegate(i.e. 35, 38, 40, 60, ect).
Do larger ones just handle more boost better?What exactly is the 'mm spec' refering to? The opening? Spring?
Thanks.
BLue n white R1
mm should be the opening and exit, the larger the wastegate the better it can handle high boost with out boost creep,
Nismo_Freak
Car: 89 Nissan 240SX
I'll just cut to the chase and say go with the 40mm. Too large of a wastegate can cause issues as well... this has to do with boost response and maintaining exhaust flow velocity to create scavenging.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
the stock TB for the SR is like 50 or 60mm anyways im pretty sure so there really isnt any point in going larger in my opinion.
SWIFT_DRIFT
The wastegate and TB (throttle body) are not related in any way shape or form J-spec :P
Nismo_Freak
60mm TB :)
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
35 or 40mm wastegate is all you'll need on a motor that size.
Paul
Movingviolation240
Paul
IvanS13
Car: *** & Titties
Thanks for the info... I wasnt all too sure. I am prolly gonna go with a 40mm.
