That's a bad idea since the BOV will most likely be getting its vaccum from the cold side. Nice way to overboost.9240sx wrote:T it off the BOV vaccum line.
+1. Have your hot pipe modified.karmakaze wrote:or have a nipple welded on.
So taking the pressure signal from the cold pipe is a bad idea even though that is how the OEM setup is configured? Need I mention the fuel pressure is regulated off of actual manifold pressure as well.Dori Dori wrote:If you know how a turbo and wastegate work you'd understand why its important (for proper boost control) to get the wastegate signal as close to the compressor as possible. I'm not hear to school sarcastic know-it-alls so reseach it yourself if you really want to know. X1000000000000000000^3 lolllerz n00b omg hahaha.
Corky Bell wrote:Unless unusual circumstances dictate, hook the wastegate signal to the compressor outlet and call it a day.
Pressure will build in the system as you accelerate. As I said above, the sensor for my WGA is tapped into the intake manifold just after the throttle body. (like yours) When the signal gets to the WGA it then causes the waste gate to open and maintain pressure at the level set by the WGA. That delay can only be a issue if there is a spike high enough to cause predetination... On the 2.0 motor that more than likely won't happen I'm on the t-2small and not having any issues with spike... IMO it's fine. But what do I know, I'm new to the sr. maybe the sr is completely diffrent from any other turbo motor out there.9240sx wrote:Iv been running mine like this for years,And never had a problem with it.I did notice faster spool up time running like this,then with it on the hotpipie.How would you overboost running it like this???
Corky Bell's book is not the end all to turbocharger performance. It was written so long ago that it has passed it's prime.Dori Dori wrote:Look, you can get the signal from any preassure source, even the brake booster line if you wanted to. I said, and it is 100% absolutely correct, for proper boost control - no spikes, no overboosting - get your signal from as close to the compressor as possible. Read Maximum Boost, page 147 - 148. Pressure from the cold side is fine but you CAN run into problems like off throttle engine bucking or boost spiking although your boost response will be better. This is obvious since the pressure will be delayed to the wastegate.
Well, many factory bypass valves are made to leak at high boost preassures to prevent spikes from damaging the engine...a fail-safe. I doubt mr. hardcore even meant to bring factory bypass valves into the discussion since he did say BOV. Relief Valves also exist to perform the same function but again, nobody's talking about that.virus77 wrote:how does a blow off valve stop a car from boost spiking?
Regardless of whether or not this is true, the wastegate theory presented is still accurate today since wastegate functionality has stayed the same. Period.HardcorePS13 wrote:Corky Bell's book is not the end all to turbocharger performance. It was written so long ago that it has passed its prime.
Despooling. Nice. Did you make that word up yesterday or find it in some uber-discreet engineering book? How do I even answer this question now?HardcorePS13 wrote:Off throttle bucking? The BOV is open, how exactly is the engine going to buck as a result of the wastegate's position being open or closed given that the turbocharger is despooling regardless.
HardcorePS13 wrote:Boost spiking? Right, if you don't run any sort of blow off valve. Kinda hard for a small turbo to overpressurize intercooler piping with a 30mm hole in it.
