hotbox240 »
https://forums.nicoclub.com/hotbox240-u63022.html
Fri May 04, 2007 7:43 pm
I'm just in the process of working out bugs on my 92 ka-t. I just got the ECU tuned by a shop and I've run into some issues. I'm having trouble getting my wastegate to open. I'm running an externally gated 38mm Tial with a small red spring (5.8 psi). I can get the wastegate to flutter and crack a little bit in 1st gear, but through the rest of the gears the boost just wants to keep creeping. I've seen my boost gauge as high as 12lbs I'm only running 370cc injectors so this is really sketching me out. The vacume source for the wastegate is coming right off my brake booster. I'm running a Phat Ka-t manifold with a T3/T4 57 trim, I have a .48 AR on the turbine side. Is my wastegate faulty? We took it apart and seems you have to push really hard on the valve to move it.
