Some problems with your event flow in "X is IW":
TB closes -> MGP rises to 14.5 psi
Manifold pressure does not rise when the TB closes, manifold pressure *DROPS* to vacuum, when TB closes. Maybe you meant "IC cold side pipe pressure" (pre-TB) under MGP?
IW opens -> Turbo spools down to until up to,
You have no control over how much the turbo will spool down. When the TB closes, fuel is not injected, the engine is just pumping air, no high pressure exhaust gases are produced to drive the turbo. (This is where an ALS systems come in.)
Really not wanting to sound rude, but I think you have some misconceptions about the elements of a turbo system, so I'll give you a quick rundown.
First of all, BOV and wastegate are mechanically the same thing: an air valve, the opening and closing of which is controlled by a separate air "circuit". Only, a WG is made of stronger materials, since it has to withstand high exhaust gas temperatures, and the occasional small particles, whereas a BOV only has to be able to withstand the flow of warm, clean, pressurized air. Thus, it doesn't matter, which one you put on the intake piping, you are achieving exactly the same effect.
I can see you understand, what a WG does, so I''l just explain what a BOV does. Yes, mainly it serves to protect to compressor from backflow (surge). There are two ways a BOV can be installed in:
- dump BOV: release the extra stuff into the atmosphere
- recirculated BOV: routes the extra stuff back before the compressor. Why this is much better, than a dump valve: the pressurized air that the turbo already produced is blown back into the turbo compressor. This puts almost the same pressure pre-turbo, than post-turbo, and this takes the "load" off the turbo, as the compressor is not slowed down by the vacuum before it. The turbo is allowed to freewheel this way, and it spools down much slower. But as I saw, you started to recognize it there towards the end. As for disturbing the MAF, my opinion is, you have to mate the BOV recirc piping into the intake at a sloped angle, so that it merges nicely into the air flow coming from the MAF. Having the MAF further away from said merge point probably helps, too.
And coming back to your original goal, reduced lag, and reduced instability of the rear-end when slowing into a corner(in case of RWD):
- lag: you can't really do any more about it, than correct turbo and manifold choice, and recirculated BOV (or an ALS, if you're very rich). With divided entry turbos and matching manifolds people seem to experience much better throttle on/off behavour, and part throttle response. I'm aming for a divided entry setup in the long run. Or with a little luck, it may be ready this year.
- rear-end break-out: has nothing to do with the turbo, really, since you're supposed to be off the accelerator (TB closed, so nothing before the TB matters!), and stomping the brakes. Brake setup, brake balance, diff. settings, driver skill (rev-matched downshifting) have much more role in this, than what you do with your intake air. As for how much the feathering of the throttle mid-corner upsets the rear-end, that's really up to the driver more than anything else.
