Tictakman »
https://forums.nicoclub.com/tictakman-u2357.html
Sun Jul 06, 2003 6:33 am
hey ive already emailed wd but wanted to put it on here too so here is the questions...
im in the middle of turboing my ka and i have a few questions. i got a 35 mm tial wastegate and it has two nipples on it, one on top and one on the side. can you tell me what plugs into each of them. i know a line from the compressor side of the turbo has to be routed to one of these but i dont know which one.
Another thing about the wastegate is that im not sure how to adjust boost. the stock spring was a 8 lb min setting so i ordered one that brings it down to 4 lb, how do i adjust it on the wastegate itself now?
Also i got a downpipe from someone off zilvia.net and i think its a fmax thermo coated one. i have a t3 garret turbo but the size of the bolt patterns are not the same. my turbo exhaust housing is a little bit larger that the dp bolt pattern. do they make a conversion piece for it or do i have to get a whole new dp? where do i get one that would fit?
Zak
