If you spend time reading on teh Z forums, this is the way to go, OR get the SPL ones.sijoko wrote:I had the Stillen arms for a few years and then finally decided to just use the stock upper links with spacers behind the mounts.
So the SPLs are all adjustable right?jamesmost wrote:the pos stillen arm was cracked in half rusted and pitted on the inside,the spl knock offs i bought for $189 look beautiful, have some serious weight to them. I should have my car back tomorrow and will update
I think this is what they're using.http://cgi.ebay.com/ebaymotors...wItemqsiguy wrote:Can someone post a link to these "e-bay knock off" adjustable front upper control arms?
I'm not understanding you entirely. Are you saying if you get the adjustable uppers you need adjustable tension rods?elwesso wrote:JUST AS A REMINDER!!!!!!!!!!! YOU CANNOT USE THE SOLID UPPER LINKS WITHOUT SOLID ADJUSTABLE TENSION RODS OR POLY TENSION ROD BUSHINGS!
