Ah, ok. So where does the top nipple go?crzycav86 wrote:It says optional on that line because a boost controller is optional.
+1its been fine til now, I'm not changingWDRacing wrote:For the record, on both of my SKylines all of my friends Skylines/180's/GN's and Supra's we reference the boost signal from the intake manifold and have never has a wastegate fail. In fact, we do it that way to make up for the pressure loss of the FMIC.
But thats my opinion only...I'm not an engineer. I just know I've done it that way on Garret turbo's for the last 8 years or so...be them internal or external.
Merry Christmas!!!
WD
So if you're getting 8lbs to the manifold, the turbo is actually making more. If you're definitely getting 8lbs from the turbo, then you're actually running on less than 8lbs to the engine?Florida240sx wrote:Signal at turbo is most accurate to protect your turbo. Because then the turbo will only produce 8lbs... But through your fmic you may only get 6-7lbs to the mani. So if you tap your signal from the mani you get what you plan for, knowing that the turbo is probably pushing 9-10lbs instead of the 8 you see....
It's probably a bad idea to money with the break booster line.LanceKA-T wrote:Well, I know all people here tap their boost gauge to somewhere from the intake mani.
And by tuning for let's say 10psi on the boost gauge you are unaware of the exact boost the turbo is making anyway.
I've had my JGS wastegate hooked up to my brake booster vacuum line for about 8 months now with no ill efffects. I had a problem with the line getting too hot from the turbo and cracking causing an overboost problem. To me this is safer by keeping it away from so much heat, and have actually heard that the vacuum will help the valve close faster.
Yes. Don't beleive me put a boost gauge on the hotpipe and one on the fpr. You have all the bends to compensate or and the FMIC. There is going to be a loss there no way around it. A guy did this a while back. Running 12lbs he only saw 10. And then reverse he ran 12lbs and turbo was pushing 14 at the hotpipe.Same thign with my IAP kit. I was only making liek 4.5lbs of boost with vaccum tapped off the hotpipe, when tapped off the FPR I made the 5.8psi which the spring was...Neejay wrote:So if you're getting 8lbs to the manifold, the turbo is actually making more. If you're definitely getting 8lbs from the turbo, then you're actually running on less than 8lbs to the engine?
Thats reatrded...protect the turbo? From what? If you're running a turbo that close to shelling you're an idiot in the first place.Florida240sx wrote:Signal at turbo is most accurate to protect your turbo. Because then the turbo will only produce 8lbs... But through your fmic you may only get 6-7lbs to the mani. So if you tap your signal from the mani you get what you plan for, knowing that the turbo is probably pushing 9-10lbs instead of the 8 you see....
