Washer Spray Low
yi_dennis
Car: 2014 Rogue SL
My 2014 Rogue's washer spray is very low. It only sprays the lower quarter of the windshield. I tried to adjust the sprayer, but its not the same as other cars. There is nothing in the manual about adjusting it. Any suggestions?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Are you attempting to use it with the vehicle sitting still? It's that way by design. It works just fine when the vehicle is in motion. If your vehicle is parked, Nissan assumes you're going to clean the windscreen by hand rather than run the wipers.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
who has been refilling your washer fluid? many places(quick lube style) use dirty nasty old bottles with heavily diluted junk washer fluid. that clogs your nozzles. try and take a needle to the nozzle point.
yi_dennis
Car: 2014 Rogue SL
I am using it stopped. I will try it moving and see if it is better. Thanks for the tip
yi_dennis
Car: 2014 Rogue SL
ImStricken wrote:who has been refilling your washer fluid? many places(quick lube style) use dirty nasty old bottles with heavily diluted junk washer fluid. that clogs your nozzles. try and take a needle to the nozzle point.
Its brand new, so from the factory or dealer. It has a strange design as I cannot see the individual spray nozzel. There is just one large square hole. I tried a needle, but nothing moved.
ImStricken06
2016 Kia Sorento
so hit up the dealer- let them worry about it lol
elmo14226
I have the same problem with my 2011 Rogue and have not been able to adjust the spray. In the service manual I think it says to use a needle but the nozzle doesn't seem to be movable. The manual shows specific spots on the windshield where the spray should hit. Mine hits about 6 inches from the bottom, regardless of speed, which is well below where the manual says it should be aimed. What I try to do is time the spray so it hits the wiper arm on the way down. This seem to deflect the spray further up on the windshield.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Can these be adjusted? Mine are spraying low onto the windshield. I don't want to start prying on them and damage it. I took a close look but, they look NOT adjustable to me, can someone confirm.
Thanks
Reason: Merged with existing thread
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
itsa300zx wrote:Can these be adjusted? Mine are spraying low onto the windshield. I don't want to start prying on them and damage it. I took a close look but, they look NOT adjustable to me, can someone confirm.
Thanks
Per FSM (for 2013):
Insert a needle or similar object (A) into the spray opening (1) and
move up/down and left/right to adjust the spray position.
NOTE:
If wax or dust gets into the nozzle, remove wax or dust with a needle or small pin.
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Thank you, did not know that was in the FSM.
Rogue One
2022 Honda Pilot SE
Thanks
Merged with existing thread. We have an incredible SEARCH feature on this forum. If you look to the right side of your screen, you'll notice the flashing Search link.
phmichel
Thanks
"Search first, ask questions later"
Return to “Rogue Forum”
