jroymd »
https://forums.nicoclub.com/jroymd-u69628.html
Thu Apr 26, 2018 9:31 am
I don't know if this is helpful, but let me make this comment. I have had three Nissan/Infiniti SUV's and two coupes. It seems as though Nissan designs windshield washer reservoirs to be hidden in inaccessible areas, although that might be true of all imports. In my old G35 I had a similar reservoir leak, and the service manual advised removing the entire front end fascia. The reason for this is that all the anchoring bolts for the reservoir face forward even though I could easily see the reservoir after I removed the top plate/cover that runs the length of the radiator. I found that by removing the passenger front wheel inside liner, as you suggested, and using a lot of long wrenches/ratchets/extensions (from the top and from behind) and sustaining multiple scratches and abrasions, I was ale to replace the reservoir. I had to use my fingertips a lot, and it was tedious but I did accomplish the replacement.
I don't know if FLEX SEAL would work because windshield washer solutions often have an alcohol component which is probably miscible with hydrocarbon based sealants. The FLEX SEAL guy usually demonstrates sealing water leaks not alcohol leaks. It may work but I would test it separately first.
jroymd on Thu Apr 26, 2018 9:54 am, edited 1 time in total.
