washed engine bay, now it idles rough
bluegen1e
Car: 95 Maxima GLE
A classic noob mistake. not afraid to admit it.
I washed the engine bay. covered the after market short ram intake filter so it can't be the issue. now when i'm idling there is a bit of "choking". feels like the plugs are mis-firing. but when i start to drive it feels fine - until I come to a light or a stop sign. then I feel it again.
i checked the spark plug wells. all seem to be dry except one. had a bit of moisture and i wiped it off. it reduced the choking a lot but i still feel it lightly. drove around 2 days thinking it will dry off but didnt help.
help this choking soul....
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
It comes in a can that you spray
Electro ? at AutoZone
Use to clean your electrical wires
Would probably displace the moisture
Let it dry out. Likely water in the MAFS connection.
Spray some WD-40 in each electrical connector, wipe, and reconnect.
NutriaforBreakfast
Does it run again?
I8A4RE
wd-40 on all your electrical connections and ignition plugs. Some water is in something causing a circuit to malfunction.Pull and reseat your electrical plugs....blow them out w some compressed air if you see any wetness too.
bluegen1e
Car: 95 Maxima GLE
actually i think it was my spark plug wells. i kept opening them and wiping them everyday. after few days it was minimized and went away. now im a happy camper..
thnx all u guys...
