cheepnis05 »
https://forums.nicoclub.com/cheepnis05-u120677.html
Thu Jan 15, 2015 8:23 am
I read through a few of the current posts on this topic, and will be checking on a few of the items mentioned, but wanted to run my symptoms by you all who really know their stuff.
2001 i30, ~130k mi. new NGK plugs at 100k
I have replaced 3of the 6 ign coils over the past 6 years, this is not a bad coil.
The car very suddenly would 'catch' and a few cyls would fire, but not start, and on the third or fourth try, it would eventually start. It began turning over a bit more slowly, and began to take a few more attempts to start. I replaced the battery, which eventually died completely, with a 750 cca (was 600) and while that didn't alleviate the slow/hard start condition it gave me 'quicker' starts and enough reserve to eventually get it going.
Temperature doesn't seem to have much of an effect on the starting. Runs well after that, I still get ~22-24 mpg highway.
This morning it wouldn't start, I was turning it over for about a minute and it wouldn't go, I turned to the off position and noticed that my Headlights are remaining on. This is a brand new issue. Smelled a little bit like burning electrical, but there still seemed to be spark (a cyl or 2 would fire).
Based on the initial symptoms, and reading the other threads, my best guess on the intital issue would be fuel pump/filter. Any other suggestions?
Anyone have a clue on the headlight remaining with power after the shut-off? (Note I haven't had the 45 second post shut off accessory power for a long time, long story short Nissan dealer burned out the control module by running the sunroof power through it, burned out the diode, all that stuff is completely disconnected) Seems weird to me, I am at work now, and the car is at home... what else should I check?
