What does a loose wheel bearing sound like?New2Import wrote:I have a few little things that needs to be address for warranty. Do I just make an appointment at a local dealer to get fix? Car has 26K on the clock so I want to get them done. Weatherstrip is loose on two doors and console trim is peeling. Also sound like a wheel bearing loose up.
Not sure if they are known for bad hub bearings. I haven't owned mine long enough to know these kind of things about them. I have seen members mention they have had them replaced by dealer under warranty though.I know GM is sure bad about hub bearings wearing out around 60K mi or usually under 100K mi. Their inner tie rods are also known to wear out around 30K mi...... That's pretty bad I think. Whos idea was it again...to place tie rods and balljoints under cars & trucks without grease certs???? That was a bad idea by all makers! Lifetime parts...........give me a break.....New2Import wrote:Yeah Ill know if its bad once the new wheels and tires are on and it still sounds that way. Im gonna make my appointment then. Are these cars know from bad wheel bearings?
