juicedgsr95 »
https://forums.nicoclub.com/juicedgsr95-u18654.html
Fri Dec 04, 2009 2:37 pm
Im glad I didnt go with a bigger clutch, then most this car will ever see is minor bolt-ons. Plenum spacer, HFC and a y pipe.
I have never had a problem with the clutch sticking to the floor... thank god, but i see it has been a problem with a lot of people and the slave cylinder seems to be the answer.
One other thing I noticed tonight that kinda pissed me off while looking to see if the slave cylinder is covered under the powertrain warranty is that the flywheel IS covered! They kept telling me I needed a new one, I didnt have the money for one at the time so we put the stock 67k mile one back in. When I saw that the warranty would cover it and they never mentioned it, i got a little heated.
Either way I am taking it back to them to have them do the slave and also have them replace the master cylinder. I am getting a buzzing noise over 5k rpm when pushing in the clutch to change gears, going to get their opinion on whats causing that. I can only hope for one work to come out of their mouth. FLYWHEEL.
Also with the new transmission, it seems all the gears are 'tight' , meaning it takes a little work to get it into gear. No grinding, just tight, it doesnt fall into gear like it should, takes some force. I am going to mark that up as a symptom of the slave cylinder. Hopefully replacing that will fix that problem. Unless you guys have another idea what would cause it, miss aligned shifter, ect... Never had the problem with the old trans.
