warranty ending
jryka
I have a 2015 sv with 23k miles whose 36 month warranty will end 4/30. My local dealer is just as likely to screw something up as fix it and I'm not having any problems. Nevertheless, is there anything I should have them check before the warranty expires? Thanks
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
You don't need to have anything to be checked right now, as of my experience with mine, since nothing broke yet other than doing typical required maintenance. You might think about buying an extended warranty if you are so worried about the crapper department in the stealership screwing things up. Best bet is always go to a 4.5 star or 5 star independent and experienced mechanic for anything. Go to stealership for only warranty work.
Return to “Rogue Forum”
