NewfoundlandDude »
https://forums.nicoclub.com/newfoundlanddude-u64486.html
Fri Jul 20, 2007 7:31 am
I have some pictures here of the top of the pre-cat and the manifold.There are 3 bolts cracked off, and threads can be seen right through the manifold, and continuing into the precat flange, but not through the pre-cat flange.
I want to know the easiest way to get these studs out (Top or Bottom), and how to go about it. There is an O2 sensor in the manifold, one in the precat, and another 2 in the Y-pipe that I have to worry about messing up the threads on.
Do these just punch out? Do I have to rotate them out? Should I take off the precat & Y, or should I try to remove the manifold (Scary with rusty bolts). Can it be done with everything on the car? Should I use a torch?.....Looking for some guidance here......
TOP
TOP
Under
Thanks in advance......
