HOOVER15 »
https://forums.nicoclub.com/hoover15-u98906.html
Wed Jun 11, 2008 4:31 am
I had the exact same problem with the lid/door. I noticed it the second week I had the car. I brought it to my dealers attention and they suggested having the tech look at it and if he couldn't adjust it that they would order a new one and replace it. But with that comes the chance of the replacement color not matching the rest of the fender exactly. Finally after the so called "pros" at the dealer could not figure it out, I researched it and found that many others had had the same problem. Not for sure if this is the reason for everyone else but the problem with mine was the plastic cable that is attached to the gas cap. After fueling, when the cap was put back on the cable had been twisted up and it caused it to stick out just enough for the lid/door to catch it at the bottom and cause it to buldge out. Then sittting out in the sun and heat the plastic had heated up and caused it to form itself as it was. I corrected the gas cap and cable like it should have been and then close the door and immediately could see a difference. After a few hours in the sun and heat it warmed the door up enough for it to form back like it should be. After all the pros and techs and head scratching, turns out it was something as simple as that little plastic cable causing the whole ordeal. Like I said, I don't know if this is the case with all of them, but it was on mine. Hope this helps some of uns out.
