woketman wrote:You are apparently a Nissan grunt spouting the Nissan party line and have not bothered to think this through in a thourough, analytical manner. I shall help you.
First the obvious: the after markets may be thicker (not overall, but each disk with a smaller gap). They may be slotted for better cooling.
Now the more esoteric: They may have a higher modulus of elasticity. They may have a lower coefficient of thermal expansion. They may have a modulus of elasticity to temperature curve that is flatter, thereby remaining stiffer longer at elevated temps. They may have a higher coefficient of thermal conductance.
So you see, I cannot say for sure, but I DO KNOW one thing. Everyone around here and the other forums seems to agree on one this: the Nissan rotors ARE crap! The only guy that I have seen that does not think that is a Nissan employee. Therefore I DO KNOW that I certainly cannot be worse off with the new ones I am ordering.
I'll let ya know in a year or so!!!
Dont try to talk down to me with words that you cant define without using a dictionary. Haha, you crack me up. I have never touted the nissan flag in such a way. They may be this in scientific terms, they may be that, haha you may have no evidence.
Do you have any proof the nissan rotors are crap? Do you have any factual evidence as to why your no name brand replacement rotors "may" be better. Tell me why, not why they may be better.
First, being thicker with a smaller center vain will actually decrease the rotors cooling effectiveness. (Compare front to rear brakes) Most cars will come from the factory and even replacements follow the vented front rotor with a solid rear set up. You would not want this.
Slotting does offer some benefits with cooling effectiveness for those who truly use their brakes to the point where heat is a problem. Auto-x is one example. Stock rotors may heat up to a point where the coefficient of friction drastically falls with the increase in temperature. Thus loosing pedal feel, glazing the pads, and never truly having the same bite as they should. Some aftermarket pads are made to operate in a heat range more conducent of such activities. Stock ones are not. They are designed to work well in low heat applications and provide QUIET usage for a long period of time. aftermarket ones do not care about this.
If you use your brakes in such a manner, auto-x and driving around town with a heavy foot, there is a better solution than stock. I do not believe however that a stock replacement rotor in this particular situation will avoid warping(excessive thickness variation) any better than a new stock one would. It would simply operate more efficiently in a higher heat range when equipped with pads of the same caliber.
