Warning Lights Problem
Craig Brumley
Car: 2004 G35 Sedan - 1992 Corvette
"Brake", "VDC OFF" and "SLIP" lights are on intermitently (all at once). It started Tuesday morning, Tuesday evening the battery had to be replaced. It seems to only be happening in the mornings after I've driven a few miles, on the way home in the afternoon, no problems. I don't know if the battery issue is related; it was the original battery and the car started several time earlier in the day, until it didn't...Any ideas?
qship96
Car: 1996 Infiniti Q45
check alternator output, and quickly before it destroys your new battery.
Craig Brumley
qship96 wrote:check alternator output, and quickly before it destroys your new battery.
They did that when we they changed the battery, but I will probably have it checked again tomorrow.
mmughal
Car: Infiniti G35 Sedan Middle East Version
That is so wicked i have a G35 Sedan 2008, had the similar problem my Tuesday morning same three lights which mentioned came on.. I wonder if its a batter issue, this has never happened before
My 75k service is coming i will speak to the dealer
Craig Brumley
mmughal wrote:That is so wicked i have a G35 Sedan 2008, had the similar problem my Tuesday morning same three lights which mentioned came on.. I wonder if its a batter issue, this has never happened before
Check the brake fluid level. I posted this problem in another section here and a tech suggested that it could be a low level. My level was just above the "Min" mark, I topped it off and haven't had a problem since. I think the battery issue was a coincidence.
