warning lights 04 Armada
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
cubsfan
Car: 04 Armada
Supplemental airbag light flashes off and on at all times on my 04 Aramada LE - no wreck, no change, no other symptoms what is up?
Thanks for ideas - like to avoid the dealers...
lowincQX26
Car: 05 Nissan Armada
cubsfan wrote:Supplemental airbag light flashes off and on at all times on my 04 Aramada LE - no wreck, no change, no other symptoms what is up?
this should fix it http://www.clubarmada.com/foru...t=137
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
The reset that is talked about if you follow the clubarmada link does work, HOWEVER, if you continue to have the lights re-appearing, you will need to take your QX56/Armada in for service. I had this same problem happen on my '04 QX56 and did the reset about 10 different times before I contacted my dealer. It turns out there was some sort of air bag module that had to be replaced. I have been service light free for over a year now. Just wanted to give everyone a heads up in case this comes up again!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
