Warning Light on JDM Cluster
240dreams
Car: 240's
I was just driving around today and a warning light came on. Im not sure exactly what light it is but its the one next to the gas light on the JDM cluster. It lit up red for about 5 seconds then later it came on again for about 5 seconds. I think it may be a transmission issue b/c ive been hearing some odd noises from that area and i also have a slight transmission fluid leak. The symbol looks like this:
l l l _---_ --__--Thanks in advance.
S14DrifterSC
Car: 96 240sx w/SR20DET
I also have the JDM cluster and the same thing happened to me and it ended up being the brake master cylinder. Check to make sure that it has plenty of brake fluid and if it does try bleeding your brakes. Hope this helps.
240dreams
Car: 240's
cool. ill look into that. Where is the CEL on the cluster? is that it?
240dreams
Car: 240's
I think you may be referring to the brake light (!) - this symbol. I checked all of the fluid and everything is fine. I seriously think its my transmission tho.
240dreams
Car: 240's
alright i just found out that it might have something to do with catyltic converter or something like that. i forgot to mention that i just installed a new 02 sensor also.
SpeedRacer1
Car: 1990 240SX, G35
Its a catalytic converter light that goes off when the cat is overheating or faulting. Nothing usually too important. I think it gets is signal off the O2 sensor mounted in the cat or on the O2 housing.
240dreams
Car: 240's
PHEW. Man i was worried for a sec. Yeah I just redid my O2 sensor wiring and installed a new O sensor so I guess thats why i came on for the first time. Thanks Speedracer1.
Hijacker
Car: '92 240sx Convertible
'94 F-150
looking at the back of the cluster (yes I just ahppen to have a JDM cluster sitting in my room) that light is labeled as EXH on the back. exhaust. Might want to invest in getting a new O2 sensor if the light is going off.
240dreams
Car: 240's
the light only came on when i put the new O2 sensor in and after i redid my wiring harness. its odd, it comes on and goes aways erattically.
Hijacker
'94 F-150
probably a wiring issue. make sure you have a good connection on the O2 wire.
I don't think that the Silvias came with an extra O2 sensor after the cat, so I don't think it would throw a light for that.
SpeedRacer1
I am pretty sure ALL S13's (180SX and Silvia) as well as the rest of the Silvia run had this light and extra sensor in the cat. If I remember correctly its part of the emissions requirements of Japanese cars.
I wouldnt worry about the light too much mainly because none of us ever use this cat sensor anyway.
Hijacker
'94 F-150
if you want to stop it from coming on, remove the light. Pull the cluster out and you'll notice a bunch of brown rectangles on the bottom of the back. Find the one labelled "EXH". Just simply twist and it will come out.
slow s13
Car: cars, photo, music
check your windshield washer reservoir its probly low
240dreams
Car: 240's
alright the light is constantly on now. im going to unplug the bulbIm still trying to figure out where the CEL is. Does anyone know?
DanielIser
Car: SR20 Powered '91 240SX
i just rewired the harness for my jdm digi gauges so that my seatbelt light didnt come on when the break was on and vice versa, that light is the same wire that the check engine light was on the usdm gauges. So i assume they are similar meanings.
jonny96
Car: 1995 240sx
1996 240sx SE
I know this is a really old thread, but in hunting down the cause of the cat hot light in my jdm cluster this is one of the first places I ended up. So just in case someone runs into this issue and ends up here too this light turned out to be my overdrive off indicator light on my automatic 95 240sx.
