warning light on dash
All things Altima Coupe.
heckeroth01
Car: 2008 Altima Coupe 2.5S
just got 20" rims installed on the coupe, went for like a day and then the tire pressure light looking like (!) came on and won't go off, i know my tire pressure is alright probably just messed up cuz of the bigger wheels, just wondering if i could fix it or turn it off
Bmore-coupe
Car: 08 Altima Coupe 3.5
did you swap the TPMS sensors when you switched wheels?
The sensors are in the valve stems
losenone
Car: AC 3.5 CVT K12
As stated, you dont have sensors in your new tires. Take them out of the old wheels or get new ones, put 35PSI in a plastic container and stick em in there and your set Or you could just put them in the new wheels.
BlackMamba08
Car: 2008 Nissan Altima Coupe 3.5SE
losenone wrote:... put 35PSI in a plastic container and stick em in there and your set ...
might as well just put them in your new set...
Bmore-coupe
BlackMamba08 wrote: might as well just put them in your new set...
I just didnt feel like taking them out of the stock wheels. although losenone, that is a very crafty idea
