DRIPS wrote:Just got back from Autozone....
I have four codes and all deal with timing of the engine. I used restore on my 95000 mile maxima numerous times, but I guess i should not have used it in this baby! I am going to drain it out and refill the oil tomorrow without that ****. I am bringing it to Infiniti Wednesday.
auditech10 wrote:What is 44K going to do for his timing??? He has no fuel issues so doing that is not going to solve his problem.I say get rid of the oil with your additive and see what happens. Its possible that the additive you added is clogging or just thins out the oil where it cant build enough pressure to actuate the cam adjusters. Rule out the variables first.Good luck
GJEMD wrote:I agree, Z sounds like an old woman handing out castor oil for everythingthat ailes you. BK is not the end all. The car was not running bad the day before this occurence. Unlikley carbon deposits are in play
szhosain wrote:
That is because I am your grandmother! Didn't you know that?
Regardless, and I will say this again, carbon deposits can happen overnight and cause unusual engine misbehavior. Personal experience on my M45!
The point being that your oil perhaps changed a bit due to the additive, the blow-by past your rings may have increased and burnt and now you have the engine stumbling. If this gets bad enough performance-wise, it may also throw engine codes.
I am NOT saying that I am definitely right ... just have seen many of these VK engine misbehavior issues get "fixed" with a BB-44K session.
And, yes, I would regardless change the oil out too if you are concerned about the Restore.
Z
antzrus wrote:I use the stuff once during each oil cycle change.
Q45tech wrote:Confusing an oil additive [MOA] with a gasoline detergent additive [BG44K]can lead to trouble each has its own fill location.
szhosain wrote:In general, I prefer not to add anything to the engine oils in my car. If you change the oil and filter often enough, these additives are probably pretty useless.
The only gasoline additives I do like are: BG-44K and ISOHEET. For the usual reasons ...
DRIPS wrote:The Restore tripped the Cam Shaft sensors...didnt need replacing tho. Still a 120 dollar mistake!
Back to normal tho!
BTW...anyone done this before on the 03/04 M? Were you successful? Did it flood the engine?http://www.infinitihelp.com/di...2.htm
Mammothbaron wrote: ↑Tue Jul 25, 2017 12:32 amI have a 2005 Nissan Pathfinder LE with 150k miles. I have heard good things about Restore engine additive and read the product warnings to make sure I wasn't doing something wrong. I added a can of restore and drove for about 15 miles on the interstate. After putting vehicle into park, I noticed a strange, rough jerky idle. I turned it off and let it sit while I went shopping. Started it up and drove to another store a short distance away (2 miles). At RPM above 1200rpm there seemed to be no problem. I let the car go into idle and it seemed to be the same jerky idle or worse. Now the CEL came on. I had no doubt it was the restore additive. I called customer support and explained the problem, and they said it can cause issues with sensors. I drove to autozone and did a parking lot oil change. I started it up and drove it about 5 miles and let it go to idle....it was 90% better. I then drove the rest of my 200 mile trip and i didn't have any more issues. I am waiting to hear back from Restore customer service and feel lucky I was able to correct the issue. Tomorrow I'll get the code erased and get the CEL turned off.
