It appears that it is happening more frequent now due the miles accumulating...
Here is the picture I found online and this is a G37 VQ engine. Mine only has oil seeping , but my dealer will fix it under my Elite Extended Warranty.
http://www.myg37.com/forums/g37-coupe/2 ... ce-11.html
Is seems like the paper gasket is the culprit. Possible 2008-2012 VQ engines might have or will have this issue once the miles is nearing 100,000.
I know sev , one of our forum members here , had the same issue like this and he probably the first guy who mentioned his timing cover was just replaced due to leaks.
From what I read the 2012+ VQ engine might be safe since they change the gasket from paper to metal...
So , before your warranty expires, check your engine for oil weep/seep or leaks!
