I just bought a GC4 and what you said couldn't be any more true.skydragoness wrote:The RS has highish miles (186k); I let it warm up if it's below freezing out--but i do it more for the transmission than the engine. The transmissions on these cars are delicate and I noticed if I don't let it warm up enough the shifts aren't smooth and there's some resistance. I suppose since it takes a lot longer for the transmission fluid to get warm (it's a Redline mix). I usually take the long way around to the on ramp to the highway (that's right by my house ) to give it a chance to do it's thing.
Mine has done the same thing. There are even mornings when the car will lurch forward just a bit when I let out the clutch from startup.asoomal wrote: In the mornings, you can barely move the gear shift lever, and there's a huge drop in RPM when I release the clutch when in neutral while it's warming up....shows how much resistance there really is.
Does that RS have some sort of ATWU system? I don't see how letting the engine sit idling would warm up the trans fluid.skydragoness wrote:The RS has highish miles (186k); I let it warm up if it's below freezing out--but i do it more for the transmission than the engine. The transmissions on these cars are delicate and I noticed if I don't let it warm up enough the shifts aren't smooth and there's some resistance. I suppose since it takes a lot longer for the transmission fluid to get warm (it's a Redline mix). I usually take the long way around to the on ramp to the highway (that's right by my house ) to give it a chance to do it's thing.
Ah I can see it now. Transmissions are still mostly metal boxes full of witchcraft to me.asoomal wrote:Some parts of the transmission are in motion when in neutral with the clutch disk engaged.
It somewhat helps warm up the oil.
Yep, heated seats is a requirement for any vehicle I buy for my wife, and 3 minutes can seem like an eternity given the cold winter we're having. Though she does not appreciate my alternative heating method of my consuming Mexican food and beer the night before...WDRacing wrote:I warm up my car for a few minutes when it's cold out. It takes about 3 minutes before the seat heaters kick in!
Agreed!WDRacing wrote:I warm up my car for a few minutes when it's cold out. It takes about 3 minutes before the seat heaters kick in!
Seriously though. The oil itself doesn't lubricate, nor flow as well until it's up at operating temp. That pretty much applies to the entire motor. It's designed to run at operating temps, not cold. From metal expansion to lubrication and all things in between.
You can disagree all you want, but the only negative thing about warming up the vehicle is a slight...very slight, usage of fuel.
However, allowing your engine and all it's systems a little time to work there way up from very cold before you apply any load to the engine is beneficial in every aspect. I'm not suggesting everyone go have a cup of coffee, 3 minutes is fine.
What about engines with forged internals from the factory. I don't think they have catch cans, or do they?Dattebayo wrote:Ah, now I understand why a catch-can is needed when you upgrade to forged.I always wondered about that!
float_6969 wrote:Not all forged pistons have that characteristic, but the major ones do. It's only the pistons that have this effect. The rings still seal properly when cold, it's just that the piston-to-wall clearance is too great when they're cold, causing the piston to "slap" in the bore. This can cause scuffing on the piston skirts and wear on the cylinder walls. THAT can cause blow by issues. The forged piston in-an-of itself doesn't require catch cans. The reason most forged engines run catch cans are because they usually run more end-gap on the piston rings. This causes more blow-by, and so a catch can is needed.
As for OEM forged pistons, there is another type of forged aluminum alloy that is a low thermal expansion type that doesn't suffer this side effect. On paper, it's not as strong as the other type, but I don't know that it's ever been proven to be weaker either.
