KUILLIN_DRIFTER wrote:MAF!! I went through 3 different mafs. First one worked for quite sometime and then started to fail as your describing. The 2nd one after a few weeks of working would shut the motor off as i would come to a rolling stop at a red light. The 3rd would would start up idle but not allow me to use the accelerator at all.
hope this helps diagonose your situation. Check maf voltages or use your powerfc
Damn, mine is kinda doing like your 2nd one did too. The idle drops a little every now and then, but sets back correctly. And as for my original problem, sometimes it also starts up, but then the rev start to die, but then raises, then gets a little lower, then goes up to normal.
