Kendahl »
https://forums.nicoclub.com/kendahl-u69307.html
Fri Sep 07, 2007 5:38 pm
It doesn't help to wait until the temperature needle starts to move before driving off. It takes a long time, especially in the winter, for a car to warm up at idle. There just isn't enough heat being produced.
For most of the year, I start the car immediately after getting in. I let it idle while I put on my seat belt, lock the doors, turn on the lights (after dark) and put it in gear. That takes 10 or 20 seconds by which time the oil pressure is up. Then, I drive gently until the temperature needle is well on the way to normal. During bitterly cold weather (zero degrees), I may wait an extra 10 or 20 seconds before moving off and I drive extra gently until it is warm.
