bentandbuzzin wrote:Does any other z's out there run very warm after hard driving. I took my z out on the highway for a drive and i ran it hard a few times. When i got back to my garage my temp gauge was just under the upper normal mark on the gauge. This was at idle. My cousins twin turbo does the same thing after hard driving. I know that temp is possible but seeing it that close to the hot mark scares me. Any help would be nice.
No, not normal. Could be the rad is slightly plugged, or even just years of debris build up in front of the A/C condenser which blocks off a huge portion of the air flow. Can also be a slight head gasket leak forcing combustion gases into the cooling system causing a similar condition to an air lock. Does your coolant go down so you have to top it up regularly?
