Warm shift lever shaft?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I could swear there was an ooold thread on this topic, but I can't find it.
The exposed metal shaft at the bottom of my Q's shift lever gets pretty darn warm. I'm assuming it's normal?I highly doubt the trans is getting anywhere near abnormally hot. It's near-brand-new, has a large external cooler, and shifts great. Still, I can't help but wonder.
I may end up installing a trans temp gauge just to put my mind completely at ease (plus it'll save me from loosing my trans the way I lost my Maxima's--assuming I'm still driving it in 12 years). I just need to figure out a nice out-of-the way but still readable place to mount the gauge for it.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Why the smart Q45 owner always installs an auxiliary transmission cooler.
Q45tech
A 174F transmission is still hot to the touch.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Q45tech wrote:A 174F transmission is still hot to the touch.
That was my thinking. Just wanted to be sure. Thanks, Dennis.
Q45tech
The transmission bolted to engine gets nearly equalized in surface temperature with engine block. Only the air cools the case and that requires oem belly pan to direct air so it bubbles up after engine. Still in Summer the assembly gets hot as does floor board and especially the tunnel under carpet.
Rex
Car: None
maxnix wrote:Why the smart Q45 owner always installs an auxiliary transmission cooler.
He has one, as he mentioned.
MinisterofDOOM wrote:... It's near-brand-new, has a large external cooler, and shifts great. Still, I can't help but wonder.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
But not everyone on this board does.
Q45tech
While reducing the ATF is excellant for AT internals, not sure that dropping the shift level 20F will be noticeable - the metal will still feel hot.
A fight between the AC cooling air of 70F and 174F still averages 122F. Now an extra nozzle focused on the shift lever might work or cooling coils.
