lucid215 »
https://forums.nicoclub.com/lucid215-u172374.html
Wed Jan 18, 2012 1:24 pm
Hello all,
I have been having this issue for a couple weeks now and im running out of ideas to try to fix it. When the motor is cold the car will start up but once it warms up it will not start back up. I have a aftermarket water temp gauge and noticed that once the temp gets to 140 and above the car wont start at all. once it falls below that it will start, but idle very ruff like its miss firing. give it some gas and it will smooth out and drive normal. I have a 2006 g35 coupe 5 A/T with turbonetics single kit. I have replaced the spark plugs (step colder), both cam angle sensors, coolant temp sensor, fuel pump (deashworks), battery is about 5 months old, same for the maf and throttle body. thermostat is about 8 months old and is a mishimoto t stat. I am also tuned on uprev program. i am clueless on how to fix this issue. any help will be great.
