WAR Motorsports/ Gibson Racing
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Could someone tell me where these guys are, or what happened to them? I keep running across their insanely built RB20DET, but have not been able to find any specs (what parts etc) on it.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
THEY ARE AN AUSSIE COMPANY. THEY USED TO RUN THE CIRCUITS DOWN THERE BUT I HAVEN'T HEARD ANYTHING ON THEM RECENTLY.
rbsileighty
That's the problem, I found out who they were and what they made (something around 480hp with loads of boost and high redline), but I can't find out what's in the motor. The website doesn't work either. These high hp 20's seem to be kept a secret. WD hasn't told us what was in his (found out about the turbo by accident), and I can't find anything on this one.
I'm not mad or anything (wanted to make sure WD knows if he reads this), but I'd really rather build a 20 instead of a 25.
masamunex03
Car: nor is this
t04e(i believe) alky injection, non turbo cams. Somehow i remember reading that somewhere. I'll check and make sure I'm right
masamunex03
Car: nor is this
"For the money I'd probably take the RB20. I had mine pushing 450 on a daily basis with all stock internals. I lowered my CR though. I couldn't get the stock pistons to hold over 28 psi. I also needed larger cams. I had swapped in the cams from the DE version since you pick up 8 degree's duration. But I needed atleast 256 cams to take advantage of the larger turbo and higher revs.
With a set of cams and forged pistons I would have been over 500whp.
All of the above was done with Alcohol and on my Skyline." WD
http://www.nissaninfiniticlub....+cams
rbsileighty
Very interesting, thanks a lot!
meggala
the gisbon mtor sport rb20 was based on the gtsr motor wild cams and build forged every thing very large t3 possibly t4.I would go 440 cc injecotrs andbig cams etc but I still reckon the rb 25 is the better base to start from for that much power.meggala
btw the description of wd's motor was correct
