WClark wrote:So from my understanding there has been previous issues with older Rogue models vibrating.
yes, but its not that big of a deal, if you simply ignore it. nothing is broken ,its just a bad design in some ways.
engine vibrates due to programeed low rpm to keep fuel economy down.
transmission vibrates like crazy due to cvt being a belt driven transmission versus gear driven transmission.
a/c compressor is a steel plate design, versus cork clutch-pack
strange half-shaft axle design on the passenger side.
I know the 2015-16 is a new design,
its just lipstick on a pig
Does anyone know of any fixes that worked to stop the vibrating or what is causing it? Apparently Nissan says it is part of the design, which I frown upon because it sounds pretty terrible in the older videos. I can't find a new video for the new models vibrating, so I don't know how bad it is.
there are no fixes miss. there is nothing wrong with the car - its just a poor design. its like being born with 1 leg an inch shorter than the other one. there is no fix, just learn to get around it lol
If you own a Rogue and have encountered this, were you able to find out the cause, able to fix it or do you just drive it like it is? And how often and when does it exactly occur?
if there was a fix - nissan would fix the cars. there is no fix.
Again, I can't find much information about the newer models, only that it still vibrates. (And as to where it vibrates, I don't know except a lot of people are saying it is super common with these cars). I took one out for a test drive and it drove beautifully. Most people say they don't notice till about 1k miles after.
you wont notice it, because you're in the honeymoon phase. you'll notice in about 3 months (all the weird quirks that its).
I really want this car, it literally has all the functions I would love. However, I need to convience my husband this would be a good choice. I am not sure if the vibration is fixable and if it is a make it /break it thing?
let me convince you of something: as someone who has moderated this forum for many years, i have seen waaaay to many issues with:
cvt transmissions were replaced on like 30%-50% of all rogues
poor a/c hardly cools the cabin
poor heater hardly heats the cabin
horrid brake issues due to small/light weight braking components used to shed weight to increase MPG. brakes wear and calipers seize way to often(prematurely)
crappy build = rocking seats, cheap plastic, door seals let in whistles, etc.
freezing navigation/infotainment system
rattling in the cabin from rear bench seats
front right axle going bad around 75,000
etc etc etc.
ill rename the thread so that its not infringing on prior open threads - as i see you simply need some advice as to buy this car or not.
my vote: go test drive a hyundai santa fe or kia sorento. after owning many nissans & infiniti's - i bought both new santa fe & sorento. talk about an amazingly built cars. idk what happened to nissan, but it seems after 2004 everything started going downhill.
