Wanted: Q45 fuel pump
europan
Car: Q45
I need a '95 Q45 fuel pump ASAP, my is dead. If you have one or know where can I find it for <$200 please call me 813-735-3699.
qship96
Car: 1996 Infiniti Q45
Used is such a bad choice on such a critical,known wear item on a Q-especially when you can buy brand new from Joe at I.O.S. for around $235
Woot!
Car: 1991 Infiniti
I recently replaced mine and found out that it is the control module and not the fuel pump, I still have the old one but as Tech said I would highly recommend you get a OEM one from Scottsdale Infiniti.
Q45tech
The fuel pump control module usually doesn't survive owners allowing fuel pumps to slow enough, and overheat and fail...................
Be sure to hand clean the bottom of fuel tank and change fuel filters frequently if you want to extend time between pump replacements.
Q451990
Woot! wrote:I recently replaced mine and found out that it is the control module and not the fuel pump, I still have the old one but as Tech said I would highly recommend you get a OEM one from Scottsdale Infiniti.
The typical failure is that the high current draw from a failing pump kills the control unit. So if your controller fails, it's usually due to a bad pump. Replace the controller without replacing the pump and you have a good chance of toasting the new controller. I know you said you replaced both... I'm just putting this here in case someone reads this in the future.
europan wrote:I need a '95 Q45 fuel pump ASAP, my is dead. If you have one or know where can I find it for <$200 please call me 813-735-3699.
Check out the old posts (search FPCU, Fuel Pump, Fuel Pump Control Unit) in Infiniti Online Mechanic, Infiniti General, and the Q45 Forums. You can ground the FP on a temporary basis to get it running while you wait for your new pump and new or used FPCU. There are also some threads on repairing the FPCU if you're good with a soldering iron.
Heath
xr4racer
Car: 1992 Q45
I have a 10k mile 1992 out of a clean tank, call me 330-289-0536
matt
xr4racer
Car: 1992 Q45
fuwl pump and controller are sold
matt
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
Deatschwerks is running a special on Walbro fuel pump and hardwire kit. Only until 1/1 however.
zerothread/295802
qship96
[QUOTE=Denver90Q]Deatschwerks is running a special on Walbro fuel pump and hardwire kit. Only until 1/1 however.
Why compromise performance,when Joe has the correct Infiniti pump for $235,which should give you 100,000 + miles use if you clean tank upon installation and change fuel filters annually.
Best to order 4-5 fuel filters when you order a new pump,serves as a constant,friendly reminder on your shelf to service them annually.
Denver90Q
Walbro is almost a $150 savings over OEM and they have good rep. Actually the guys on the VH/VK forum recommend them. Thats why.
qship96
Foolish move to use anything but factory fuel pump.....Walblo is not a special design 3 speed pump like factory part
"Smart people learn from their mistakes....really smart people learn from the mistakes of others"
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
Denver90Q
The only thing that makes it a 3-speed is the controller which can be bypassed.
Obviously you haven't learned from your mistakes.
qship96
A fool and his money......
Classic case of confusing price with cost
