govtworkhorse »
https://forums.nicoclub.com/govtworkhorse-u50364.html
Tue Jan 01, 2008 7:33 pm
So basically you have a fuel delivery problem correct?
1. Fuel tank full?2. Fuel pump prime when key turned?3. Do you know what you have as fa as fuel pressure?4. Fuel feed/return lines on backwards?
What I would do while you are waiting for a reply on here, is go out and test some things. First off, when you turn the key to "ON" position, can you hear the fuel pump prime? If no, check wiring/pump. If yes, then turn off key, take fuel line off (the line with filter on it) and place in a coke bottle or something. Have someone turn the key back on and see if a steady amount of fuel comes out with a good bit of pressure. If not, check fuel filter. If it does come out, you may have fuel rail/injector problems. Also make sure it's not super old stale fuel.
After you do that, let me know what happens. This might fix your problem and save you from paying someone a load of cash.
